CFL flame tip bulbs?
Welcome Dan.....hoepfully you will stick around and it helps to put your location in your profile.
First off, I would never buy any bulbs off fleebay....
My local Costco was selling the same bulb for about the same price....
Yes, they do make dimmable CFL's in that style.....I would suggest that your browse Amazon or Lamps Plus web sites for more options.....or just go down to your local HD or Lowes.
I have a few of those in my house...but I don't dim them.
If your going to do dimming...make sure you have the right dimmer....a standard flavor dimmer for incandescents will not work for CFL's. Go to the Lutron web site for exact technical details.
Unless cost is a big issue, you might want to look into LED bulbs. That size is much more affordable...and LED's are better suited to dimming than CFL's.
Lastly....consider color....if this is for a chandiler...I would suggest not useing warm white (2700K). I would go with a 4000K or so color...that will look much better with a bunch of cristyl around it.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
