CFL Bulbs And Light Fixtures... - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 11:08 AM   #1
CFL bulbs and light fixtures...
I am a new homeowner and had a pretty basic question.
IF a light fixture says max 60w..... can I put in there (2) 26 watt CFL bulbs?
or do I need to look at it as... since 26watts is equivalent to 100w incandescent...... so I will going over the wattage (100w times 2 bulbs) with 2 of these??
Anyone have a good brand to recommend for CFL bulbs.... I am looking for a daylight bulb... looking for a cooler, brighter light. Probably as compact as possible... so they will fit inside these small fixture the contractors install.
Any opinions?
RitzLondon is offline   Reply With Quote
Old 12-17-2012, 11:16 AM   #2
Yes. That just means that the light output of the 26 watt cfl bulb is supposed to be equivalent to the light output of a 100 watt incandescent, it really uses 26 watts
mterry is offline   Reply With Quote
Old 12-17-2012, 11:33 AM   #3
So for a fixture that says 60w max, I am ok with (2) 26w CFLs???
Old 12-17-2012, 12:00 PM   #4
Special User
Rewards Points: 1,230
Yes, from an electrical wiring and fire safety standpoint, 2x26W CFLs consume 52W and are completely safe to put in a 60W luminaire. Electrically, watts is watts -- the "incandescent equivalent" is used only for comparing light output (lumens). IMHO we should just use lumens and forget about this "equivalency" junk.
However, if this is an enclosed fixture, or one that the bulbs screw in base-up, you may find that the CFLs don't last as long as they should. The electronic ballast inside the CFL tends to slowly cook itself. When I buy fixtures, I try to get ones that mount base-down or at least base-sideways. If I do get a base-up fixture, I make sure the bottom is open or there are ventilation holes/slots.
You asked for bulb recommendations. I'm using "micro-mini" 3500K Sylvania CFLs in my bathroom. The base is kind of fat, but otherwise the curly part is no bigger than an incandescent and should have no trouble fitting in a tight fixture. They are instant-on, but come on a bit dim and take a minute or so to brighten up. That's actually good, so I don't dazzle my eyes first thing in the morning. Once they warm up they give a nice clean white light without being harsh (but I realize that's subjective).
I hate the dirty yellow light that 2700K bulbs make. Sylvania does make a 6500K "daylight" bulb, and I have used daylight bulbs in the past, but now I'm really digging these 3500K bulbs. They're not a hard blue like 6000K bulbs, but they're not yellow either -- kind of a Goldilocks "just right" color temperature.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Blinking LED light bulbs northerner Electrical 5 04-11-2012 12:30 AM
5 Watt A15 light bulbs for bath Metallo Appliances 2 01-22-2011 08:54 PM
Light bulbs blowing,,, Woodcutter Electrical 12 09-15-2009 06:24 PM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 07:16 AM
