-   -   CFL Ballast replacement (http://www.diychatroom.com/f18/cfl-ballast-replacement-165600/)
Travlnman 12-04-2012 06:19 PM
Hey all, I have 9 5 inch cans with the 4 pin plug in CFL bulbs and one of the ballast is bad. Have any of you all replaced a ballast in a can that was installed when the house was built? If so, how in the world do you get to the ballast as the cans are in the kitchen between floors. Any help would be appreciated.
stickboy1375 12-04-2012 06:29 PM
12 Attachment(s)
Remove the lamp, and feel around inside the can, you'll come across a wing nut of sorts or a junction box cover with a tab that will release a cover, inside that will be the ballast, and no joke, these are always fun to replace. :)
Travlnman 12-04-2012 06:35 PM
Thanks for the reply, unfortunately the wing nut only adjusts the socket up and down for length of the bulb. The ballast is actually external to the can and the wires feed through a hole in the top of the can. There is 3 screws that look like they attach the inner sleeve of the can to the frame but I am not sure if that will allow me to pull the can down in order to get to the ballast.
stickboy1375 12-04-2012 06:36 PM
12 Attachment(s)
Yep, remove the 3 screws and pull the down on the lamp housing.
Travlnman 12-04-2012 06:41 PM
Thanks for the help, I will give it a try.
stickboy1375 12-04-2012 06:42 PM
12 Attachment(s)
They are never fun, so good luck.
Dierte 12-04-2012 09:56 PM
Ill second that sticky.
ddawg16 12-04-2012 10:16 PM
I'll third that.....
Which is why I went with standard cans with the Edison base...lets me use either a regular CFL or LED. In the near future I'll be removing the Edison socket and puting in a GU24 socket.
frenchelectrican 12-04-2012 11:29 PM
I have done few in both resdentail and commercal side so therefore it is NO fun try to change the ballast it will be not easy to work around.
You will need to be extra pataince with it and take your time with it.
Before you start to disconnect the old ballast take a look at the new one they useally have 4 to 6 leads in the ballast connnection beside the power supply so you will have to be creative with this one.
One trick I am sure it will work is use the mirror and use flashlight or flourscent troublelight up the hole where the recessed can located ( yeah 3 screw and it will come down.
Merci,
Marc
