CFGI In The Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 05:00 PM   #1
Unhappy
CFGI in the bathroom
Bought a mobile home. Want to replace a regular plug in the bathroom with a CFGI as it's dangerous as it is now. Not sure how he has it working but this is how I see the configuration.
Power from box into the bathroom switch - then switch to the lights above the sink - then to the plug (non-CFGI) - then to a switch which controls the exhaust fan in the bathroom.
I'm not kidding when I say the configuration was working without a hitch. The switch for the fan worked as long as the lights in the bathroom were turned on as well as the plug was working as long as the lights in the bathroom were turned on. When I removed the old plug to install the CFGI I wasn't paying attention to the wiring and now I'm stuck. I do not know how to wire the power from the lights to the CFGI to the switch for the fan. Can anyone help with a simple diagram on how to wire them together. This would be hugely appreciated.
Thanks - Hutchcove
hutchcove is offline   Reply With Quote
Old 11-20-2011, 05:14 PM   #2
Licensed electrician
Rewards Points: 1,634
It would help greatly to know the number and colors of the wires you are dealing with.
The only wiring that you needed to concern yourself with was on the receptacle. If these are the only wires just place the black wire on the brass LINE and the white to the silver LINE terminals. Connect the bare or green to the green screw.
Code05 (11-20-2011)
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
