CFCI Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 06:20 PM   #1
CFCI outlets
When wiring a circuit in a basement or garage do all the outlets in the circuit need to be cfci or just the first in the circuit?
lwhiting is offline   Reply With Quote
Old 05-12-2011, 06:24 PM   #2
Electrical Contractor
kbsparky's Avatar
I think you are referring to GFCI protection?
Only unfinished basements require all the outlets to be GFCI protected. Finished basements can have non-gfci protected outlets in some areas.
All garage outlets require GFCI protection.
You can provide GFCI protection by using one or more GFCI receptacles, or a GFCI circuit breaker.
-KB
Old 05-12-2011, 06:27 PM   #3
So when you say:
Does that mean I can have one CFI outlet in the beginning of the circuit and that will protect the rest of the circuit?
Old 05-12-2011, 06:57 PM   #4
kbsparky's Avatar
Originally Posted by lwhiting View Post
...Does that mean I can have one CFI outlet in the beginning of the circuit and that will protect the rest of the circuit?
Yup. Except it's GFI
-KB
Old 05-12-2011, 08:09 PM   #5
Licensed electrician
Rewards Points: 1,612
As long as the downstream receptacles are wired from the LOAD terminals they will have the GFI protection.
Old 05-12-2011, 08:40 PM   #6
So it it line in load out or load in line out? I've been told both ways.
Old 05-12-2011, 08:47 PM   #7
Mad Scientist
Line = upstream, Load = downstream. Anything connected to the Load terminals of a GFCI will be GFCI protected.
McSteve is offline   Reply With Quote
Old 05-12-2011, 09:18 PM   #8
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The downstream outlets also have to be labeled 'GFCI Protected'
There are usually labels to that effect in a new GFCI package.
Caution on adding more than a few downstream outlets to a single GFCI because of the increased possibility of nuisance tripping due to long runs especially in wet locations. GFCI's are still cheap and it is always easier to isolate a GFCI tripping problem when individual GFCI's are used in an area.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
lwhiting (05-13-2011)
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
do I need GFI for all kitchen counter outlets DanDaMan Electrical 2 03-06-2011 06:33 AM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
