Certain Plugs Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 04:55 PM   #1
certain plugs not working
Some outlet plugs dont work in my house. Can it be that they are all bad? Is it a fuse issue?
jnut is offline   Reply With Quote
Old 07-14-2009, 05:30 PM   #2
dSilanskas's Avatar
Could be a few things. If the plugs are in the same room or around the same area check the fuses. And if the fuses are fine than you could have a bad connection at a plug
dSilanskas is offline   Reply With Quote
Old 07-14-2009, 06:58 PM   #3
we checked the fuses and changed the plugs
Old 07-14-2009, 07:05 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Probably the most common problem with a outlet (receptacle) not working is a poor connection from installing the wiring into a 'backstab' instead of under a screw....over time these backstab connections often fail.
The problem may very well be at a working receptacle...so if you only replaced the ones that didn't work you likely missed the bad connection.
It will shorten the troubleshooting a bit if you invest in a receptacle tester like this.....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
central ac not working like it used to diyer1 HVAC 12 07-15-2009 02:30 AM
KO plugs are dangerous! Ultrarunner2017 Electrical 10 11-25-2008 06:57 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
