Central Vacuum Wiring Rough-In - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 11:03 PM   #1
I moved into a new townhouse with a central vac system roughed in. I mounted the canister in the garage near the PVC stub that was coming from the ceiling. I connected the PVC tubes to the canister inlet. There's one low voltage wire that runs along the PVC stub from the ceiling. I took that wire (2 small wires inside - white and black) and connected to the canister. Everything seems to work.
There is one suction outlet downstairs and one upstairs. Neither work when I plug in the hose. I remove the outlet plates to find that the wires in them are not hooked up to the screws on the plate. I hook them up. Now the outlet downstairs works, but upstairs does not. I used a multi-meter and there is a current running in the downstairs low voltage wiring, but no signal at all upstairs.
Can't figure out why, and how to get it working upstairs!!! Any clues?
ebayhoey is offline   Reply With Quote
Old 07-09-2011, 11:43 PM   #2
Electrical Contractor
kbsparky's Avatar
Probably the wire is tucked in behind the downstairs inlet. Look for another set of wires in and behind the inlet.
-KB
Old 07-10-2011, 04:08 PM   #3
Thanks for your reply kdsparky.
Damn, I see a couple of wires running inside, I tried tugging at them. They move a bit, but they aren't really budging, so I can't find the wire end, if there is one. I'm afraid if I tug too hard, it will displace the whole line of wire running between the walls and screw something up. Should I try tugging harder? Why didn't the contractor hook up these wires? Can't see any downside in doing so and would've made things a lot easier for me.
Tags
low , problem , vacuum , voltage , wiring
central vacuum amba Electrical 1 03-13-2011 06:15 PM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
wiring my condenser fan to my central air unit 45lonnie Electrical 1 09-05-2010 10:52 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Central Vac Wiring Dar Electrical 10 02-27-2009 05:22 PM
