-   -   Central Vacuum Wiring Rough-In (http://www.diychatroom.com/f18/central-vacuum-wiring-rough-110189/)
ebayhoey 07-09-2011 10:03 PM
I moved into a new townhouse with a central vac system roughed in. I mounted the canister in the garage near the PVC stub that was coming from the ceiling. I connected the PVC tubes to the canister inlet. There's one low voltage wire that runs along the PVC stub from the ceiling. I took that wire (2 small wires inside - white and black) and connected to the canister. Everything seems to work.
There is one suction outlet downstairs and one upstairs. Neither work when I plug in the hose. I remove the outlet plates to find that the wires in them are not hooked up to the screws on the plate. I hook them up. Now the outlet downstairs works, but upstairs does not. I used a multi-meter and there is a current running in the downstairs low voltage wiring, but no signal at all upstairs.
Can't figure out why, and how to get it working upstairs!!! Any clues?
kbsparky 07-09-2011 10:43 PM
Probably the wire is tucked in behind the downstairs inlet. Look for another set of wires in and behind the inlet.
ebayhoey 07-10-2011 03:08 PM
Thanks for your reply kdsparky.
Damn, I see a couple of wires running inside, I tried tugging at them. They move a bit, but they aren't really budging, so I can't find the wire end, if there is one. I'm afraid if I tug too hard, it will displace the whole line of wire running between the walls and screw something up. Should I try tugging harder? Why didn't the contractor hook up these wires? Can't see any downside in doing so and would've made things a lot easier for me.
