Central Vacuum Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 10:07 AM   #1
sko
Central vacuum wiring
Our new home is roughed in for the central vacuum. The low voltage wires come out with 'U' shape (the bottom of 'U' outside)
from the hole where the connector is to be connected. I don't
know how the connection can be made. Should I cut the wire?
sko is offline   Reply With Quote
Old 03-25-2012, 10:34 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
Depends on the system. Can you take a pic of the wires and also what the connectors/plates look like? Even a link or name of the system you are using would help.
Not all rough-in plates are the same. What brand was used for the rough-in?
Old 03-28-2012, 10:47 AM   #3
sko
Smile
The brand of my vacuum is HOOVER.
Thanks.
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 09:23 PM
Central Vac wiring...how do I get a light to go on? wease Electrical 4 02-22-2007 07:27 AM
re-routing central vacuum pipe yummy mummy Building & Construction 2 12-03-2006 04:30 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
