Central Vacuum - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 04:37 PM   #1
central vacuum
4 wires - red, green, yellow and black - connected 2 wires every where - machine works and 2nd floor work - 1st floor and basement don't - any advice??? thanks
amba is offline   Reply With Quote
Old 03-13-2011, 05:15 PM   #2
somewhere the wire that was used is damaged or not connected properly. If you are able to test the continuity of the wires from one vac head to the other that would be able to tell you where the damage is. There should be two wires at each head except for the last one in the run which will have one. The wire that was used is phone wire. Thats ok for this but if two colors of wire dont work , try the other two on all the vac heads. Maybe just one of the wires used is damaged and not all of them. Make sure all vac heads have the same to color wires used. Try different combinations of colors at the vac heads . Also at the vac unit be sure to change the colors there too.
lcjay is offline   Reply With Quote
no wiring for the central vacuum mgamike Electrical 16 01-03-2011 03:53 PM
Central vacuum - how does the low voltage wire go into the low voltage receptacle? ILIFFE Electrical 4 09-29-2010 10:04 AM
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
Testing a Central Vacuum with no hoses or heads MrLinux General DIY Discussions 1 01-23-2008 03:44 PM
re-routing central vacuum pipe yummy mummy Building & Construction 2 12-03-2006 04:30 PM
