Central Vac Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 11:13 PM   #1
Question
Central Vac problem
So my house has central vac roughed in, and I finally bought a central vac. I got everything installed but I am having a problem with the wiring for it. There was low voltage wiring already run from the outlets to downstairs. The central vac came with blade connectors, and I think this is my point of bad connection because when I plug the vacuum into the outlet they installed for it (it says central vac right on it), the unit does power up however the unit won't turn on when I put the hose into the outlets.
I stripped the black and white wires leaving only the copper exposed, pried open the blade connectors, put the copper wire in the 2 slots, and squeezed it back together, but when I try to plug the blade connectors into the unit It doesn't go in very well, or it's loose depending on how much I squeeze/open the blade connector. Is there a trick to this, or maybe this is right and my problem is somewhere else?
While writing this I thought of a possible other problem. There are 2 wires, one coming from the sweep tray, and 1 coming from the outlets (2 outlets right above one another (1st and 2nd floor). Should there be 2 wires for the 2 outlets, or would they have spliced them together behind the wall resulting in only the one? My central vac only has 2 low voltage inputs so hopefully thats not the problem!
I'm a huge amateur when it comes to electrical work so I apologize if this isn't quite clear, I can provide pictures if need be!
Thanks for any advice.
strongbow is offline   Reply With Quote
Old 10-19-2010, 10:31 AM   #2
bump!
Old 10-19-2010, 05:35 PM   #3
Mad Scientist
I think probably you should add some pictures, as I for one cannot quite visualize what you're saying, especially regarding the blade connectors.
McSteve is offline   Reply With Quote
Old 10-19-2010, 08:34 PM   #4
Rewards Points: 6,652
You need to cut the bare Copper off of the ends, and place the insulated wire in the connector, then press down the cover. What happens, is that the metal in the one piece "bites" into the insulation to make connection with the Copper. It is the same procedure if you were wiring Keystones for networking or telephone wiring.
Old 10-23-2010, 08:49 PM   #5
CV low voltage wiring
Strongbow,
the vac pan has wiring which can tie together with the other wires before connecting to the vac. Each inlet should have wire running from it to the vac or to the next inlet in line depending on how the system is wired. If you are connecting multiple wire pairs match them by color. At the vac, I like to then coil about 3 feet of wire around a pencil or thin srewdriver, this will make a nice tidy coil to attach to the vac. Crimp as Gregzoll explained, use small twist connectors to join the balance of wires to your coil and for added safety take about 6 inches of slack at the end of the wires and loop into a knot. Its a low voltage system so worst case if you create a short the vac will run until you unplug the spade connectors.
Chemist1961 is offline   Reply With Quote
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Central air quit cooling seems like only fan is running Rochelle HVAC 5 08-11-2009 09:24 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
