Central Vac Keeps Running - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 09:12 AM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,630
Sometimes when the FIL pulls out the hose from the wall, the vac keeps running.
Is there a relay that sticks or something?
Thanks,
Pugsy
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 12-28-2013, 09:22 AM   #2
Rewards Points: 14,300
Do all of them do it or just one?
http://www.thinkvacuums.com/trouble.htm#troubleshooting
123pugsy (12-28-2013)
Old 12-28-2013, 09:23 AM   #3
Master Electrician
Rewards Points: 3,960
Brand, model #, photos? Relays are usually at the vac unit. More likely wall contacts not opening when the hose is removed.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 12-28-2013, 09:27 AM   #4
123pugsy's Avatar
Pics: I'll have to get the father in law under bright lights and grill him on the particulars...
Old 12-28-2013, 12:00 PM   #5
123pugsy's Avatar
I will wait until the next time it happens and give a little tap/wiggle at the wall outlet to check that first.
Thanks everyone.
Old 12-28-2013, 09:15 PM   #6
Rewards Points: 960
I would say you have a small piece of conductive shinola on top of the contacts on the inlet.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Old 12-28-2013, 09:54 PM   #7
deverson's Avatar
Rewards Points: 77
Remove one of the low voltage wires from the canister. If it turns off it's out in the hOuse somewhere. If it keeps running its inside the canister.
deverson is offline   Reply With Quote
The Following User Says Thank You to deverson For This Useful Post:
Help!! Sump pump won't stop running! kukubura Plumbing 25 11-02-2012 09:06 AM
Carrier Cool & Heat 8.81 lbs Charge, comp. not running - fan is running justplumducky HVAC 23 07-27-2012 12:52 PM
Heil Gas Furnace Keeps Running doombilly HVAC 2 11-13-2011 09:27 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
Central air question please help..... hollywood123 HVAC 2 07-10-2007 02:07 PM
