Central Exhaust Fan, Adding A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 12:25 PM   #1
Central Exhaust fan, adding a switch
Hi, I am currently working on adding a bathroom to my basement and would like to add a bathroom fan. My home has a central exhaust fan, where each upstairs bathrooms feed into it. The switches in those bathrooms are in parallel. Each switch will turn the fan off and on, but one does not turn the fan off if the other turned it on (ie.. not a 3-way).
I am assuming it is wired something like this...
https://picasaweb.google.com/lh/phot...eat=directlink
Power may go to the fan first, but I'm not 100% sure.
Now to add another switch for the new bathroom, the question i have is if it is wired like this, will the new switch need to be on the same circuit? Or could it be on a separate circuit and meet up with the other prior to entering the fan. I'm assuming it would need to be on the same circuit and in parallel to the other switches, but just wanted to confirm.
Thanks.
fumbrunner is offline   Reply With Quote
Old 11-16-2012, 12:28 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Same circuit.
Old 11-16-2012, 12:47 PM   #3
Figured as much. Thanks for the response. I need to double check to make sure power isnt going to the fan first, rather than to switch one. On the other hand, that would probably make for an easier installation of the new switch.
Insufficient flow from exhaust inducer - won't actuate pressure switch FunWithTools HVAC 30 11-04-2012 07:10 PM
Adding wiring for under cabinet lights from a three way switch Dale8 Electrical 0 10-07-2012 02:50 PM
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Adding exhaust fan to existing light circuit EelectricP Electrical 1 08-19-2011 09:31 AM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 12:43 AM
