Central Air Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 01:22 AM   #1
Rewards Points: 332
Central air wiring question
The old aluminum wiring for my A/C is oxidized and I'd like to replace it. Based on the info on the tag, I should be able to use a 30A breaker with 12 gauge or larger wire, correct?
Thanks.
sgip2000 is offline   Reply With Quote
Old 10-07-2012, 01:55 AM   #2
Pure Genius
Rewards Points: 150
No. size for your min breaker
Dierte is offline   Reply With Quote
Old 10-07-2012, 04:10 AM   #3
Electrician
Rewards Points: 150
The OP is correct, that's the code. And for short distances there's no down side for #12 wire. For longer distances, esp. through hot attics, there is power lost as heat from the resistance in the wire. Upgrade the wire a little and you can recoup your investment with lower bills. By the way, aluminum is a perfectly good conductor. A wire brush, some Noalox grease and a torque screwdriver will make for efficient long lasting connections.
Glennsparky is offline   Reply With Quote
The Following User Says Thank You to Glennsparky For This Useful Post:
sgip2000 (10-07-2012)
Old 10-07-2012, 04:55 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,892
Totally incorrect. #12 on a 30A breaker is just fine in this application. In fact, I'm pretty sure #14 would be allowed since it is actually rated 20A (25A for 90C) but, like #12, is subject to a special maximum breaker size for most types of circuits - but not this one.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 10-07-2012, 06:08 AM   #5
An old Tradesmen
Rewards Points: 6,476
12 is fine. Myself I would use a 10, but code allows 12.
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-07-2012, 08:56 AM   #6
Electrician
Rewards Points: 776
What are you talking about, if this was true he should be wiring it with #6 or #4 to save even more money.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
brric (10-07-2012)
Old 10-07-2012, 09:26 AM   #7
Rewards Points: 2,516
hammerlane is offline   Reply With Quote
Old 10-07-2012, 10:00 AM   #8
Rewards Points: 332
Thank you. I do plan on using 10ga.
Old 10-07-2012, 10:03 AM   #9
Rewards Points: 332
Thanks for your input. True, aluminum is fine, but since I have the copper, I'd like to just replace it.
Old 10-07-2012, 11:57 AM   #10
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
If you use a fused disconnect it has to be #10 to the disco, then #12 to the unit. Non fused can be #12 from the panel all the way.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Old 10-07-2012, 06:32 PM   #11
Rewards Points: 332
I got it done with 10-2 to the fused disconnect and kept the 8ga whip that was already there.
Thank you everyone.
Old 10-07-2012, 07:27 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Depending on what code cycle you are on, you could use #14 AWG. and a 30 amp breaker.
The Following User Says Thank You to stickboy1375 For This Useful Post:
mpoulton (10-07-2012)
Old 10-07-2012, 07:28 PM   #13
E2 Electrician
Why would you use 10 AWG? It serves no purpose.
Old 10-07-2012, 07:47 PM   #14
An old Tradesmen
No idea how long his run is. but less voltage drop on those hot days when the compressor has to start. Also, don't have to run a new wire down the road if he adds on and needs to increase the size of the A/C to something that has a min cir amp of 25.
No real cost difference between 10 and 12.
Old 10-07-2012, 07:49 PM   #15
E2 Electrician
yes, there is... I personally would wire the unit with 14 AWG.
AC wiring question? Ralph III Electrical 4 03-04-2012 11:52 AM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Low Voltage Wiring Question.. scyarch Electrical 3 10-23-2011 12:00 PM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
