Central Air Condenser Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 09:57 AM   #1
Rewards Points: 77
Hello All,
I'm a DIY'er for most things except things that I want perfectly done and I know my limits. My brother is a licensed Master electrician but has really only dealt with Commercial last several years - his company are commercial electricians who setup new building contruction etc..
Anyway, my wife and I are getting Central Air from our tax money this year. That project starts in two weeks. My brother is going to tie everything together for me (electrical) but I had to do the research and buy everything. The HVAC installer said I need a 30A 2P GFI breaker to a 30A disconnect on the side of my house. I have the breaker specific to my panel, 10-2 wire and PVC conduit, etc.
Question:
I did purchase a 30A fusible pull-out disconnect box and 2x 30A NOS type H fuses. Will this work? The condenser is a new Trane XB13 and I can't find any documentation stating it needs fusible over non-fusible.
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 04-20-2012, 10:03 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Skelleyman View Post
Hello All,
Question:
Thanks,
~S
Unless the manufacturer requires fuses, use a non-fused disconnect. GFI is not required and is not necessary. A GFI receptacle is needed within 25' of the unit for service.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-20-2012, 10:58 AM   #3
technically, the 25' receptacle doesn't need to be GFCI, only 'accessible'. for an outdoor unit though, 99.99% of the time that receptacle will be outside and thus need to be GFCI protected.
itsnotrequired is offline   Reply With Quote
Old 04-20-2012, 12:48 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 244
What are the specs for the inside unit?
If you do not have the required receptale, then you will have to pull a circuit for that as well.
jbfan is online now   Reply With Quote
Old 04-20-2012, 01:08 PM   #5
Rewards Points: 80
Any master electrician regardless of expertise should know this answer and be able to help you through the complete installation process. Or if not familiar, should be able to consult a code book for every single answer.
The Following 2 Users Say Thank You to J. V. For This Useful Post:
Code05 (04-21-2012), Speedy Petey (04-21-2012)
Old 04-20-2012, 01:34 PM   #6
electures's Avatar
I was refering to the outside unit, and the 25" GFI receptacle. What 25' receptacle are you refering to?
Old 04-20-2012, 01:51 PM   #7
i was just commenting that 210.63 doesn't explicitly state that a service receptacle for air conditioners needs to be GFCI, as 210.63 doesn't differentiate between indoor and outdoor units. it only needs to be accessible which means for an outdoor unit, that receptacle is going to almost certainly have to be outside which now makes it have to be GFCI, per 210.8(A)(3).
this is more of a 'break the code' exercise than anything else. i mean, say that next to the outdoor air conditioner was an unlocked storage shed on stilts. this accessory building is not at grade so it could conceivably have a receptacle inside which is not GFCI protected yet is accessible and within 25' of the air conditioner. i know, i know, not a realistic scenario but it is possible. inspector would probably make you have a GFCI anyway.
Old 04-20-2012, 02:33 PM   #8
electures's Avatar
Should be interesting to see what some of our "real expertz" have to say about this.
Old 04-21-2012, 05:55 AM   #9
Code05's Avatar
Rewards Points: 1,104
I would ask how a receptacle in a building on stilts/ not at grade complies with these parts of 210.63.
....shall be installed at an accessible.....
The receptacle shall be located on the same level.....
Accessible (as applied to equipment). Admitting close
approach; not guarded by locked doors, elevation, or other
effective means
Code05 is offline   Reply With Quote
Old 04-21-2012, 07:29 AM   #10
the answer to ur ? is yes ull b fine with what u have. ive had years in comm. and resid. so i understand ur relative not knowin much about wiring houses or troubleshooting them cuz they r a lot diff. in a lot of ways. not sure y ur goin pvc, if its gonna b visible id go with 3/4 emt it will look a lot cleaner (pvc never gets straight, plus over time it will bend with summer heat.) id probly bump my wire up to #8 thhn (romex if not piped the whole way, set a box if needed in attic to change to pipe cuz that romex is a lot more compared to single thhns. depending on how long u plan on livin there u might kick urself later if u ever get a larger unit that runs 40a and it all has to b re done.
parteeman is offline   Reply With Quote
Old 04-21-2012, 07:37 AM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
Wow!
I don't know if you are on a phone or not, but this is impossible to read. I looks like a 13 year old girl wrote it.
The Following 5 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (04-21-2012), Evstarr (05-01-2012), HIVOLT (04-21-2012), jbfan (04-21-2012), kbsparky (04-21-2012)
Old 04-21-2012, 07:37 AM   #12
I completely agree.
Old 04-21-2012, 09:04 AM   #13
Electrician
Rewards Points: 778
I agree any electrician should be able to do this, I am sure he has hooked up roof top units before and for the most part an air conditioner outside your house is like a roof top unit.
darren is offline   Reply With Quote
Old 04-21-2012, 11:45 AM   #14
Code05's Avatar
Originally Posted by Speedy Petey View Post
Wow!
I can decipher enough to know that he/she has no clue about 430/440 and sizing units.
The Following User Says Thank You to Code05 For This Useful Post:
Old 04-21-2012, 12:07 PM   #15
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Wow!
Oh come on, give em a break. They can't be expected to take that extra time away from partying to spell and punctuate.
The Following User Says Thank You to k_buz For This Useful Post:
Ravenworks (04-21-2012)
Installing central air question about conduit from disconnect to panel angelas111 Electrical 2 05-27-2011 08:37 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
wiring my condenser fan to my central air unit 45lonnie Electrical 1 09-05-2010 10:52 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Moving condenser electrical disconnect, required? Dave Carney HVAC 7 07-27-2009 11:34 PM
