Old 06-21-2009, 10:53 AM   #1
cell/email notification in the event of a power outage
i have been searching for something that can send me an email/text message when our power goes out at home. our house sits in a wet location so our sump pump runs pretty much non stop. we have a portable generator we use to keep the pump running if the power goes out while we are at home. my fear is the power will go out while we are on vacaton and flood our newly remodeled basement. if i could find something that could send us a notification of power loss i could call a friend to go to our house and start our generator until thepower comes back on. any suggestions?
Thanks,
justin
jorourke is offline   Reply With Quote
Old 06-21-2009, 11:28 AM   #2
WFO
Our POCO experimented with a device that plugged into the wall outlet and connected to the phone line. When the power failed, it would call the utility and report it.
After finding out that they would often rack up hundreds of dollars of long distance charges on the homeowners phone bill when they failed (the power was still on), we discontinued the project.
Whatever you decide on, get a history on performance from somebody other than the salesman.
WFO is offline   Reply With Quote
Old 06-21-2009, 12:14 PM   #3
I Googled "power outage notification" and found several hits, such as http://www.diycontrols.com/product_i...4d6ac6c3319ef6
Some battery backup units can be set to do notifications.
Old 06-21-2009, 11:11 PM   #4
I have my APC ups hooked up to a linux box. It sends me an email to my BlackBerry whenever the power goes out or there is a power dip. It also sends an email when it comes back up, so long as it wasnt several hours and the UPS went dead.
They make the software for Windows as well. Just make sure that your internet (DSL Modem or Cable Modem) and any other networking gear is on a UPS as well, or the email wont go out.
Total cost for my solution was just the cost of the UPS. (Note, several of the cheap UPS dont interface well with software to send alerts. Cyberpower is one of them.)
Subject: ENVIRO enviro Power has Failed
DATE : Sun Jun 21 22:33:22 EDT 2009
MODEL : Back-UPS ES 350
STATUS : ONBATT
LINEV : 000.0 Volts
LOADPCT : 45.0 Percent Load Capacity
BCHARGE : 100.0 Percent
TIMELEFT : 15.9 Minutes
SENSE : High
LOTRANS : 097.0 Volts
HITRANS : 127.0 Volts
LASTXFER : Input frequency out of range
NOMINV : 120 Volts
Subject: ENVIRO enviro Power Restored
DATE : Sun Jun 21 22:33:24 EDT 2009
STATUS : ONLINE
LINEV : 119.0 Volts
MAXTIME : 0 Seconds
SENSE : High
XONBATT : Sun Jun 21 22:33:22 EDT 2009
XOFFBATT : Sun Jun 21 22:33:24 EDT 2009
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 06-25-2009, 01:40 AM   #5
AndrewF any chance you could send me more info. on your setup? what apc ups you are using and software?
thanks,
justin
Old 06-25-2009, 10:35 AM   #6
This is the software I use on my linux server.
http://www.apcupsd.com/
-Andrew
DIY hobbiest
Old 06-25-2009, 12:25 PM   #7
DIY'r
ScottR's Avatar
jorourke - I have a similar setup to Andrew's. Definitely a good idea.
But, you might also want to look into a battery-backup sump pump, or a water-powered backup pump. If your friend isn't around to turn on the genny, you might be SOL even with the notification.
ScottR is offline   Reply With Quote
Old 01-18-2010, 12:42 AM   #8
STATUS : ONBATT
LINEV : 000.0 Volts
SENSE : High
NOMINV : 120 Volts
STATUS : ONLINE
LINEV : 119.0 Volts
MAXTIME : 0 Seconds
SENSE : High
Andrew,
What APC UPS do you have and is it enabled for text message alerts when used with this software you have referenced?
paulw517
paulw517 is offline   Reply With Quote
Old 01-18-2010, 01:26 AM   #9
sdsester's Avatar
I read recently about a guy who set his house up with its own Twitter account. Sensors posted regular messages. I will see if I can find the article.
I definitely think a back up battery for the sump a good idea whatever you figure out.
sdsester is offline   Reply With Quote
Old 01-19-2010, 02:12 PM   #10
Ran into the same kind of thing. The text message is a bit hard (I have not found one less than $300 plus monthly fees) but you can get a low cost phone dialer with power loss feature. They have their own battery back up and will dial up to 4 numbers and play a recorded message (such as the power is out at xxx)
Here is one of the links but there are plenty of suppliers. The sensor with the dialer will set you back about $125.
http://www.specialtyalarms.com/site/...product/80-513
Dan
DSmitts34 is offline   Reply With Quote
Old 01-19-2010, 09:00 PM   #11
I have a water alarm with a sensor that is attached to the sump pump pipe at a determined height when power is lost and water rises it senses a high water level and triggers a phone dialer that calls my cell phone
kerry42 is offline   Reply With Quote
Old 01-19-2010, 09:48 PM   #12
Kerry42,
What a the specs/info on this autodialer for cell phone alerts? Does it require a standard land line? I need a text alert when my power goes off and my PC goes into the UPS backup batteries.
paulw517
Old 01-21-2010, 07:49 AM   #13
Yes this does need a land line ( Phone Line) it also uses 2- 9 volt batteries is very easy to install ,I have tested several time and works with no problems dials my cell and leaves a message . they also have freeze alarms..Kerry
Old 02-06-2013, 02:04 PM   #14
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
All cell phones text message systems tie your number to an email address. You just find out what that is by looking it up. Att is your area code and phone number @txt.att.net
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-06-2013, 05:46 PM   #15
http://www.amazon.com/Reliance-Contr...190770&sr=1-10
curiousB is offline   Reply With Quote
Power Outage Issue? rbjones6 Electrical 13 05-24-2011 01:59 AM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
Breaker tripped after power outage. What's up? Leah Frances Electrical 14 02-12-2009 07:56 PM
power outage jp66hill Electrical 4 01-22-2006 08:24 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
