Ceiling Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 02:59 PM   #1
ceiling wiring
Hi
just looking at the wiring in our new house. The bathroom light fitting wiring currently features 2 lives tied together as well as 2 earths tied together. Neither combination is used with the actual light fitting. Can sort of understand this tying together in a "1-way" sense but am intrigued why they used the 2 neutrals for hooking up to the light fitting?
ChrissyWissy is offline   Reply With Quote
Old 04-25-2012, 10:00 PM   #2
Rewards Points: 14,312
Sounds like the wire continues on to power something else. A fan?
Old 04-25-2012, 10:20 PM   #3
Master Electrician
it's for the switch, the incomming black gets tied into the black going to the switch, the white is used as the return from the switch and should be marked with black tape or paint or something lol. The white from the incomming is the actual neutral. so it's really not too whites attached to the light but a white and a white wire that should be identified as a hot wire.
andrew79 is offline   Reply With Quote
Old 04-25-2012, 10:25 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
In the states, the remarked white wire will/should be the feed to the switch, and the black the switch leg.
This keeps from having 2 white wires to connect to the fixture.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-22-2011 11:04 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
