In-Ceiling Speaker Installed In Soffit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 12:47 AM   #1
Rewards Points: 308
In-Ceiling speaker installed in soffit
We are revamping our patio area a bit which is off of our sun room. I was wondering if anyone has ever heard of installing in-ceiling speakers in soffits? If so, could you provide some tips in doing so? Thanks!
smokey847 is offline   Reply With Quote
Old 04-21-2012, 01:06 AM   #2
Rewards Points: 6,652
Get outdoor grade speakers.
Old 04-21-2012, 10:41 AM   #3
There are many different styles and brands of flush mount ceiling and wall speakers you can purchase....many different quality levels as well. Just do a search on google. It is definately do-able. Just install to the manufacturers specifications. If they require a back-box...typically they will come with it.
lowvolter is offline   Reply With Quote
Old 04-22-2012, 08:36 AM   #4
I ran across a nice set of Marine speakers I use on our patio. They are completely sealed so water will not hurt them if you happen to get a lot of rain or whatever.
If you find a deal, they are nice looking white speakers, round and about 7" in diameter.
Good Luck!
Mm
Mmfh is offline   Reply With Quote
Old 04-22-2012, 10:44 AM   #5
Just a suggestion but flush mounted speakers in the soffit may not project sound in the right direction. Plus, once you cut holes in the soffit if you ever have to replace the speakers you must use the same size or bigger. There are fully enclosed styles which attach using a bracket. Then you can angle them towards the center of the patio rather than toward the ground. They are more visible which may not be appealing to you. Just a suggestion. I use wireless speakers that I take out to the patio when I want to use them but I have considered a more permanent solution like yours. Good luck!
USAF93 is offline   Reply With Quote
Old 04-23-2012, 07:30 PM   #6
Rewards Points: 308
Great. Thanks for the responses. Would anyone happen to be able to point to a picture of the in-ceilings in a soffit? Thanks!
Old 04-23-2012, 07:46 PM   #7
Just a DIY guy
http://www.outdoorspeakerdepot.com/
They have a photo of one in a soffit here
http://www.outdoorspeakerdepot.com/o...-speakers.html
M3 Pete is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Installed New Ceiling Fan/Light and Light Doesn't Work mojoe_24 General DIY Discussions 7 07-17-2009 04:30 PM
Can I run speaker wire in conduit in ceiling Leah Frances Electrical 17 01-15-2009 01:16 PM
Moving Air Return from Floor Soffit to Ceiling Soffit mehaley HVAC 4 07-20-2008 12:00 PM
