Old 11-02-2009, 08:30 PM   #1
Default Ceiling power cord
Hello I'm knew here. I have a question in regards to power cords from the ceiling. I have a small bakery that has a prep table in the center of the room that I use mixers and such ,is it code or allowed to have a power cord that is attached to a electric box thats mounted above a drop or grid ceiling to power these small appliances .The cord would have a cord grip at box and have a female cord end the cord would be 12/3 so cord .
kerry42 is offline   Reply With Quote
Old 11-02-2009, 08:33 PM   #2
nap
You talking to me?
nap's Avatar
You can hang a recep in a proper box
or you could install a recep pointing downward at the ceiling.
I don't care for that type of install simply due to the situation of where the recep gets weak and has difficulty retaining the plug.
Old 11-02-2009, 08:43 PM   #3
Home Slave
Lazy_Jake's Avatar
I've seen this in hobby shops and metal shops and such....I don't see why not. Just make sure that you can access them easily to unplug in an emergency.
Lazy_Jake is offline   Reply With Quote
Old 11-02-2009, 08:46 PM   #4
Extreme DIY Homeowner
Scuba_Dave's Avatar
They also have retractable cords
This may be considered a "kitchen" setup & need GFCI
Not sure on commercial electric installs proper code.....
How much power do these draw?
You may need more then one circuit
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-02-2009, 08:58 PM   #5
nap
You talking to me?
nap's Avatar
I would have to hunt code sections to be sure but I am pretty sure you cannot do this above a lay-in ceiling.
Old 11-02-2009, 09:38 PM   #6
Default power cord
I should have said that the box would be a 1900 box mounted to the grid with the proper mounting bracket and a ring would be attached to the box and be flush with face of the tile and that trim single gang cover fasten to the box with a 1/2 knockout and a cord grip with the 12/3 cord then attached.
Old 11-02-2009, 10:44 PM   #7
Thumbs up Issue of cord on grid ceiling
Don't know the Code on this. But common sense (and some experience, installing Grid/Drop Ceilings) tells me that unless the (1900) box is reinforced by a chain (inside the DC) or extra reinforcement by tie wire of the immediate area of the box, it should not be done due to the unintentional, forceful yanking (not to be confused with NY Yankees) of the cord. Which could bring down the box along with part of the ceiling. (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-03-2009, 12:14 AM   #8
" Euro " electrician
Nap .,
If I recall it have at least 4 sections related to this code situation reguarding of the box above supended ceiling and if that is air handling space the bet is off you know how strict it is.,,,
One related to proper stand off
Second is the proper box to support the drop cord
there are few more I have to dig it up
Oh yeah .,,
To OP
You can not use the shallow or deep 1900 box at all it is not allowed in food prep area you have to use as one of the member posted the yellow box aka woodward heads that what I called them or use FS box { that is diecast box with threaded hub in there }
Merci,Marc
Old 11-03-2009, 12:39 AM   #9
Child Alert! Pull Up!
fltdek's Avatar
I'd call the local county/city inspector and ask them, don't necessarily have to tell them who you are....but at least ( I would hope) they would know for sure in your area.
fltdek is offline   Reply With Quote
Old 11-03-2009, 10:13 AM   #10
Electrical Contractor
Don't have the code section, but a cord is not allowed to pass through a drop ceiling, weather hardwired or plug connected.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-03-2009, 10:33 AM   #11
nap
You talking to me?
nap's Avatar
I'll have to look now because of your post but I have never had an inspector shoot down the woods box (with proper restraints/supports above) hanging below a lay in ceiling.
Old 11-03-2009, 11:23 AM   #12
Default power cord
I not sure if I am explaining it well. I will be mounting a 1900 box ABOVE the ceiling tile and proper mounting will be done to secure the box to the grid with a bar hanger that attaches to the grid ( not sure of the exeact name of bar hanger that clips to the grid runners above the ceiling ) at that point there will be a drywall ring installed so that ring would be FLUSH with the face of the ceiling tile.You would NOT see the box only the opening from a single gang ring ,the box would be piped to another j box for power and wire pulled for a feed . I would then take a single gang ss steel blank cover plate and punch a 1/2 ko out and attach a cord grip with 12 /3 SO cord and terminate a female 20 amp cord end. The cord would only extend from the ceiling about 3 feet down.
Old 11-03-2009, 11:49 AM   #13
kbsparky's Avatar
Sounds doable to me. Section 400.7(3) would allow such a setup.
As long as you don't have that cord passing through or located above the ceiling [see sections 400.8(2) and 400.8(5)]
-KB
Old 11-03-2009, 01:38 PM   #14
Without looking I believe the box needs threaded hubs and strain reliefs too.
Old 11-03-2009, 02:22 PM   #15
kbsparky's Avatar
You guys are not reading the OP's specs correctly.
There is NOT a box hanging down, so no threaded hubs or strain reliefs are needed at the terminating end.
It is a 3 foot cord, with a female cord cap installed on the end. The strain relief will be at the beginning (fully exposed), fastened on a blank plate mounted flush at the ceiling.
Section 400.7(3) allows this to facilitate the "Connection of portable .... appliances."
Section 400.8 does not apply in this case, as the flexible cord will not be located within the suspended ceiling, nor concealed.
-KB
More On This Topic
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
How to Hang a Fan
How to Hang a Fan by eHow.com
Ceiling fans are a way to help cool a room during the summer and circulate warm air during the winter. They're available in many styles and with numerous lighting options to match the decor of any room. There's no need to hire an electrician to hang a... Read More »
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. Now we are going to hang the fan into the hanger. You would note the slot in the ball go inside these small balls in here. Now we are going to... Read More »
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. Now that we have successfully removed our existing old light fixture, we are ready to open up our box and with our new ceiling fan it in it... Read More »
Hi! I'm Joey Gunz and you can check me out on line at www.joeygunz.com. I here on behalf of Expert Village to bring you the final and 16th part of our improve your photography tutorial. In today's session, what we are going to be talking about is high... Read More »
Baseboard Heater / Power Cord Problem channingg General Discussion 8 10-02-2009 01:35 AM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 04:40 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 10:23 PM
Wall AC power cord options J187 Electrical 2 04-13-2007 06:12 PM
How do I make a power cord for.... Justin860 Electrical 0 03-03-2007 07:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
