The Ceiling Lights Go Out After 10 Minutes - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 08:17 PM   #1
The ceiling lights go out after 10 minutes
The lights go out in my kitchen after 10 minutes. The circullar light bulb is new. I flick the switch on and off without success(Lights occasionally flicker). After awhile, I turn the switch on and the lights are on again. But after 10 minutes, the lights go out again. What kind of problem am I having?
Randy
pghdude2480 is offline   Reply With Quote
Old 06-30-2011, 08:23 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
Make sure the lamp is inserted into the prongs all the way.
Sounds like a ballast overheating.
jbfan is online now   Reply With Quote
Old 06-30-2011, 08:39 PM   #3
They are inserted all the way. I first encountered the problem a few weeks ago. I thought the issue was the circular light bulb that was originally put in hence I bought a new one. I moved in to the house at October 2010, and the kitchen lights were fine until a few weeks ago. The issue I'm having now is the same as the one a few weeks ago.
Old 06-30-2011, 09:00 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
I'm guessing the ballast is about to give up the ghost.
Kyle
Old 06-30-2011, 09:09 PM   #5
What are my options?
Old 06-30-2011, 09:15 PM   #6
jbfan's Avatar
Rewards Points: 382
Replacing the fixture will be easier than finding a ballast.
Old 06-30-2011, 09:15 PM   #7
kbsparky's Avatar
Replace the fixture. Problem solved.
-KB
Tags
electrical , go out , lights
need help removing ceiling fan and installing recess lights craig83170 Electrical 1 09-06-2008 07:27 PM
ceiling & wall lights diynovice1 Electrical 5 07-30-2008 02:10 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
halogen lights fitted into a polystyrene ceiling - safe? jono_wales Electrical 1 03-07-2005 02:52 PM
