Ceiling Lighting Wiring Help - Urgent - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 06:19 AM   #1
Hi Everyone.. new here!
My better (or worse) half accidentally hit the lighting fixture in our kids bedroom this morning, subsequently breaking one of screw catches.
Now, I can wire and the rest of our property has the correct mounting plates but this is...different...
It needs a new lighting fixture and preferably I'd love to do it today but this looks a bit of a hash job to me..
Can anyone please advise how to sort this out etc?
Have attached pics of how it's looking...
John
Jippers is offline   Reply With Quote
Old 05-02-2010, 07:31 AM   #2
DIY staff
Rewards Points: 7,174
Yikes---No box---You are going to have to install a box there..If you can get to it from above the job is fairly straight forward. Easiest would be a 4 inch box with a round ring.
If you must attack this from the ceiling side--consider using a box with an adjustable bracket--these are usually found at the Depot in the lighting section----they allow you to do the entire install through a hole no bigger than the box.(which is included in the kit)
They are a bit pricey at $12.00--But you can get the light in without having any drywall repair.
----Mike---
Old 05-02-2010, 07:57 AM   #3
----Mike---
Hi Mike thanks for the reply...I think I may end up doing so..
here is the view on the loft side of things...
There are two switches here, one wall and the other is a ceiling mounted pull cord hence all the black wiring...
all fun..
Old 05-02-2010, 08:05 AM   #4
DIY staff
Look like you have a plan---Good luck--Have fun--Mike--
Old 05-02-2010, 08:07 AM   #5
well the plan is not to kill myself ...
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
wiring a ceiling light that branches off to outlets What have I done Electrical 7 08-11-2009 09:24 PM
Ceiling Fan and Recessed Lighting with No Attic Access...Ugh. caps84 Electrical 1 08-06-2009 11:09 AM
ceiling lighting using electrical receptacle with no switch cedar Electrical 8 02-03-2009 07:00 PM
Ok to run wiring between strapping in the ceiling? peeks Electrical 5 08-29-2005 01:12 AM
