Ceiling Light Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2007, 12:17 PM   #1
Ceiling Light problems
The ceiling light in my hallway just stopped working. Power was getting to the bulb holder, but I changed it. Power is definitely getting to the holder but will not illuminate the bulb. I have tried a few bulbs so this is not the problem. Is it something basic or am I losing my reason?
David Cleere is offline   Reply With Quote
Old 07-14-2007, 04:36 PM   #2
Lic. Master Electrician
Your light bulb may not be screwing in all the way to make the connection. The metal tab at the bottom of the base may be pushed down all the way to where there is no connection when bulb is screwed in. Turn power off from the breaker and try to pull up the metal tab a little bit so that there can be a connection. Give that a try and see if it works.
idoelectric is offline   Reply With Quote
Old 07-15-2007, 02:21 AM   #3
Thanks, but I don't think that is the answer to the problem.
I am in Ireland and we generally use the bayonet type bulb. And I'm fairly sure that contact is being made.
Old 07-15-2007, 03:31 AM   #4
How do you know you have power? If there is voltage and the bulb is good, then it should work.
Old 07-15-2007, 10:08 AM   #5
I've used a tester which shows there is power.
Even though I have attached a new fitting I'm going to attach yet another one (on the assumption that proper contact between bulb and wires is not being made) but I'm not optimistic. I cannot understand why the light should simply stop functioning in the first place.
Thanks for your interest - I'll let you know how I get on.
Old 07-15-2007, 10:14 AM   #6
Home Improvement Guy
ron schenker's Avatar
Is it on a dimmer?
ron schenker is offline   Reply With Quote
Old 07-15-2007, 12:01 PM   #7
Thanks, ron, but it isn't
Old 07-15-2007, 01:51 PM   #8
Well, I'm beaten!
Power is coming through and all other lights on the circuit are OK. Am I cracking up?
Old 07-17-2007, 03:53 AM   #9
Master Electrician
JohnJ0906's Avatar
Where exactly are you measuring power? At the lampholder? The wires?
What are you using to measure with?
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-17-2007, 06:13 PM   #10
joed's Avatar
Rewards Points: 12,944
Depending on the type of test you are doing for power, you could have an open return wire.
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 08:10 AM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 09:16 PM
