Ceiling Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2008, 07:26 AM   #1
Ceiling Light problem
I've just installed a new light fitting in my utility room which works fine but now both the dining room and kitchen lights wont work, any ideas folks?
Smiler is offline   Reply With Quote
Old 05-25-2008, 08:12 AM   #2
Electrician
Going to need a little bit more info for this one.
chris75 is offline   Reply With Quote
Old 05-25-2008, 08:27 AM   #3
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Check the connections in any junction box you opened. Sometimes a wire will sneak out of a wire nut as you tighten it.
John
jrclen is offline   Reply With Quote
Old 05-25-2008, 09:28 AM   #4
joed's Avatar
Rewards Points: 13,696
You wired something wrong. You need to give us more details of how you connected things together if you want more details of how to fix it.
Old 05-26-2008, 08:40 AM   #5
I bet you knocked a neutral splice apart when you put up that new light. Take the new light down and make sure all the neutrals in that box are spliced together tightly.
Super33 is offline   Reply With Quote
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
