Ceiling Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 05:05 PM   #1
ceiling light problem
Hi Everyone
I have a ceiling light which has gone out and not because of light bulbs burnt out. Have taken down the light and all connections look good. When the light is hanging I can put a bulb in and the light turns on. When I reinstall the ceiling light (accomplished through a centre bolt and nut in the base of the light which you tighten to hold the ceiling light in place). Now that the nut has been screwed into place, the light won't go on. Now if I place a rubber washer between the centre bolt and the nut so that I can still screw the bolt into place but it is isolated from touching the ceiling light base, the light will go on.
Any thoughts
al gilliland is offline   Reply With Quote
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Help- cant get a new ceiling fan light to work boddabing Electrical 6 08-26-2010 06:24 PM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 07:24 PM
Ceiling Light problem Smiler Electrical 4 05-26-2008 09:40 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
