Ceiling Light Power Loss - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 05:22 AM   #1
Question
ceiling light power loss
when fitting a new ceiling light in our living room and turning it on at the wall(dimmer switch)it tripped the circuit breaker,since then i cant get it to work at all?it works if you put wires straight to live and neutral but not to the wire that controls the switch.if i try an electrical tester there is power there untill i introduce the wire from the light fitting then it seems to lose it,take the light live wire out and power is back to ceiling rose.can anybody help please.
pejay is offline   Reply With Quote
Old 08-12-2008, 06:37 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Tell us what wires were connected to the light, and how many wires are in the ceiling box.
Old 08-16-2008, 11:47 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I'm sorry pejay, but it's kinda hard to follow the way you are describing it. One guess is the wiring may be wrong at the light somehow, since you are saying that you replaced the light. I'd also be curious about the dimmer switch...you said it tripped the breaker when you turned it on...might have fried it. All in all, we need more info...as jb has asked for.
Old 08-20-2008, 08:11 AM   #4
2 reds 2blacks and 1 earth.
there are 5 wires in the ceiling hub,2 red 2 black and i earth.1 red and 1 black in either side of hub.black and red in 'live' side are both live,surely just the red should be live?earth goes to earth obviously.
thanks again.
Old 08-22-2008, 05:02 AM   #5
Thumbs up
thanks again.
all sorted now.it was the dimmer switch had fried,thanks for your help.
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 03:06 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
