Ceiling Light Pendant - Wattage Help Please - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 01:28 PM   #1
Hi
Broke the bottom of a ceiling pendant putting in a new bayonet bulb. The fitting had a label stating "60w bulb max". It was too dim anyway so bought a new 100w pendant.
Question is - do I need to fit a whole new pendant to the ceiling, or can I just attach the new bulb fitting bit to the pendant hanging down? Not sure where the wattage bit is- in the part connected to the ceiling or the bottom bulb section. Please help. Thank you!
moosey81 is offline   Reply With Quote
Old 08-30-2012, 02:06 PM   #2
kevinp22's Avatar
Rewards Points: 252
To have a UL listed fixture you would need to hang a whole new fixture.
Very risky to tie a larger wattage fixture to the existing one. Wire ampacity is "probably" okay but who knows about the fixtures and wiring's heat tolerance.
If you hang a new fixture, also note that if you have really old wiring in the ceiling box (pre 1986) it is probably not rated for 90 degrees C and cant handle a fixture requring 90 degree supply conductors (usually listed clearly on the box). Not usually an issue for pendant versus ceiling mounted fixtures but just want to make you aware.
kevinp22 is offline   Reply With Quote
Hanging ceiling light w/out beams J407 Electrical 29 03-28-2012 09:25 PM
Ceiling Light Help - Quiz - 3 sets of wires roundbox52 Electrical 1 03-28-2012 07:08 PM
Help- cant get a new ceiling fan light to work boddabing Electrical 6 08-26-2010 05:24 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
