Ceiling Light/fan Need A Wall Switch ? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 09:40 PM   #1
Rewards Points: 201
Ceiling light/fan need a wall switch ?
Is it a violation of NEC to directly power a ceiling/light fan that has pull switches for the fan and light, rather than go through a wall switch first ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 05-22-2011, 09:47 PM   #2
Rewards Points: 512
210.70 Lighting Outlets Required.
(1) Habitable Rooms. At least one wall switch-controlled lighting outlet shall be installed in every habitable room and bathroom.
Old 05-22-2011, 10:21 PM   #3
Rewards Points: 1,542
Which I interpret to mean that a ceiling fan and light can be powered from an unswitched feed and use pull chains while a wall switch controls a wall receptacle in the room, or the wall switch can be a master switch for the ceiling fan unit with pull chains for the fan and light.
Old 05-22-2011, 11:20 PM   #4
Rewards Points: 512
That's how I interpret the exception:
Originally Posted by 210.70A
Exception No. 1: In other than kitchens and bathrooms, one or more receptacles controlled by a wall switch shall be permitted in lieu of lighting outlets.
So, I guess the next question is: does OP have a switched receptacle in the room?
Wall switch wiring for ceiling fan Rusty Nail Electrical 2 04-25-2011 01:34 PM
Need Help Replacing Ceiling Fan Switch Carbo Electrical 2 03-17-2011 03:53 PM
Wiring a single pole wall switch to a ceiling fan and light. How ? Larry Lambert Electrical 3 03-08-2011 03:52 PM
Seperate the Light/Fan to a switch on the wall Scotsman Electrical 2 12-14-2009 05:00 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
