Ceiling light/fan dimming
I'm no expert, but this happened to me. First, look at the manual to see if the light kit support the type of lights you installed. For example, some will not accept CFL in place of incandescent. This is what happened to me. Trying to be "earth healthy", I installed the CFL in place of the incadescent and it works a bit at the beginning and then some starts to flicker or dim slowly. Although the CFL has less wattage, but it still won't work. Second, check your bulb wattage. Most light kit won't let you install combination of bulbs that total more than x wattage, 190 watts total for example. If that fails, then look to the electrical troubleshoot. It may just be a very simple troubleshoot so don't go to extreme just yet. Hope this help in some way.
