Ceiling Fixture Red Wire????? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 04:41 PM   #1
Ceiling fixture red wire?????
I took down a big light in my daughters room. One you would see in a kitchen. When I was taking it down I did not pay attention to where the red wire was attached to the previsous fixture.
On the new fixture (small, one bulb fixture) I put the black to black, white to white and the red wire is being a booger. I put the red with the white wires and the fixture would turn on, but if I turned the light switch off, the light would not turn back on and my breaker would go off.
If I put the red wire with the black wires the light would work but the light switch would not turn the light off.
If I don't put the red wire with anything, the light switch will not turn the light off.
Help!!!! Anyone know what I should do? Don't want to burn my house down.
Thanks!!
Michelle
meshell06 is offline   Reply With Quote
Old 10-19-2008, 04:55 PM   #2
Licensed Pro
Try the red wire to the black of the fixture, the white to white, and cap off the black. What you have would be typical of wiring for a ceiling fan with the fan controlled by the pull chain and the light by the switch.
Old 10-19-2008, 05:19 PM   #3
Put a wire nut on the black wire, wire black to red, white to white, ground to green or bare and you should be good.
rgsgww is offline   Reply With Quote
Old 10-19-2008, 05:59 PM   #4
Thank you. That is exactly what I needed to do.
Thank you so much for your help.
Old 10-19-2008, 09:20 PM   #5
dSilanskas's Avatar
Thanks!!
Michelle
Reason why they did that is because they gave you the option to install a ceiling fan in the room.
dSilanskas is offline   Reply With Quote
Ceiling fixture install cjhigley Electrical 5 09-25-2009 01:26 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 03:55 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
