-   -   Ceiling fixture red wire????? (http://www.diychatroom.com/f18/ceiling-fixture-red-wire-30210/)
meshell06 10-19-2008 05:41 PM
:eek:
I took down a big light in my daughters room. One you would see in a kitchen. When I was taking it down I did not pay attention to where the red wire was attached to the previsous fixture.
On the new fixture (small, one bulb fixture) I put the black to black, white to white and the red wire is being a booger. I put the red with the white wires and the fixture would turn on, but if I turned the light switch off, the light would not turn back on and my breaker would go off.
If I put the red wire with the black wires the light would work but the light switch would not turn the light off.
If I don't put the red wire with anything, the light switch will not turn the light off.
Help!!!! Anyone know what I should do? Don't want to burn my house down.
Thanks!!
Michelle
HouseHelper 10-19-2008 05:55 PM
Try the red wire to the black of the fixture, the white to white, and cap off the black. What you have would be typical of wiring for a ceiling fan with the fan controlled by the pull chain and the light by the switch.
rgsgww 10-19-2008 06:19 PM
Put a wire nut on the black wire, wire black to red, white to white, ground to green or bare and you should be good.:thumbsup:
meshell06 10-19-2008 06:59 PM
Thank you. That is exactly what I needed to do.
Thank you so much for your help.
:thumbup:
dSilanskas 10-19-2008 10:20 PM
Originally Posted by meshell06 (Post 174081)
:eek:
Thanks!!
Michelle
Reason why they did that is because they gave you the option to install a ceiling fan in the room.
