Ceiling Fan Wont Work - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 11:29 AM   #1
Question
Yesterday I Installed a new ceiling fan....When I Removed the old one it still had power. I put in the new ceiling fan and it will not work....Actually i beilieve that theres no power going to it Seems to have no power not even to the switch. What could make this happen??...Where are some places to start looking..??
markellingerjr is offline   Reply With Quote
Old 09-11-2009, 11:34 AM   #2
Licensed Pro
Tripped breaker/AFCI?
Did you disconnect any wires in the ceiling box other than what was connected to the old fan?
Old 09-11-2009, 12:17 PM   #3
no disconnected nothing else checked all the breakers....nothing else in house is without power
Old 09-11-2009, 12:33 PM   #4
Rewards Points: 58
How is the fan wired. Tell us wire by wire how you connected the fan to the wires in the ceiling box.
J. V. is online now   Reply With Quote
Old 09-11-2009, 06:36 PM   #5
BCSparkyGirl's Avatar
there is also the remote possiblilty that the fan is a factory defect....this happens too.
BCSparkyGirl is offline   Reply With Quote
Old 09-11-2009, 07:07 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Loose/bad wire connection?
Kyle
Old 09-11-2009, 10:00 PM   #7
Tools-For-The-Trades
Send a message via Skype™ to Ladderpouch.com
It seems then to be something with the way you put wire to wire - faulty fan?
Ladderpouch.com is offline   Reply With Quote
Old 09-12-2009, 04:16 PM   #8
ceiling fan won't work
markellingejr.
This ceiling fan, is it a paddle fan, or a flush mounted exhaust air type?
Post back, and I tell you my way to check out the fan. And you won't
need a ladder to do it.
user62257 is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 05:16 PM
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 02:01 PM
pull down ceiling storage crimsonalucard General DIY Discussions 16 02-27-2011 09:39 PM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-14-2009 12:09 AM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
