Ceiling Fan Wiring /w Three Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 08:21 PM   #1
Question
Hello, first post here. I've looked all over the place and I can't seem to get an answer to my question. I have a ceiling fan with a light kit and two, three way switches in a room in my house. I would like either switch to turn on/off both the fan and the light at the same time. I have wired it several times and I cannot seem to get a configuration that the breaker box likes. It always cuts the power off in that room. Also, sometimes the power stays on until I flip the switches but i do not understand what I need to do. Here is a picture of my setup that might make more sense. If anyone knows how to wire the system I am wanting up I would appreciate some help on where each wire connects to.
ttodd1292 is offline   Reply With Quote
Old 10-17-2012, 12:39 AM   #2
"So I Re-Wired It"
MisterZ's Avatar
how many wires are at the light fixture box??
if you're not messing with the 3-way switches, and they worked fine before....
a typical setup would be to nut both the Blue and Black fan/light wires to the Black(hot) comiing from the 2nd 3-way switch.
Ground is self explanatory, and Neutral to Neutral.
now if you do not know which wire is which, then obviously you will need to determine which is the Hot, and which is Neutral.
get a good digital ohm/volt meter. do not rely on non-contact probes, they can be unreliable
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
The Following User Says Thank You to MisterZ For This Useful Post:
ttodd1292 (10-17-2012)
Old 10-17-2012, 08:01 AM   #3
Rewards Points: 2,516
try this,,,ground wires not shown for ease of drawing
Ceiling Fan Wiring /w Three Way Switch-lite-power-fan-light-combo-6.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Old 10-17-2012, 08:44 AM   #4
joed's Avatar
Rewards Points: 11,990
Connect all the grounds together.
Connect live white to the fan/light white.
Connect the live black to the switch white.
Connect the switch black to the light blue.
If you want the fan also switched connect the fan black to the switch black also.
If you want the fan not switched connect the fan black to the live black and the switch white.
The Following User Says Thank You to joed For This Useful Post:
Old 10-17-2012, 02:15 PM   #5
I'll try this when I get home. Thanks very much
Help wiring a ceiling fan with 3-way switch and dimmer csbaker80 Electrical 4 06-15-2012 04:59 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Wall switch wiring for ceiling fan Rusty Nail Electrical 2 04-25-2011 02:34 PM
Need Help Replacing Ceiling Fan Switch Carbo Electrical 2 03-17-2011 04:53 PM
