Ceiling Fan Wiring Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 08:56 PM   #16
Rewards Points: 3,256
Originally Posted by drew15a View Post
LOL. 1960s.
Another poster mentioned 1860. No knob and tube for you.
zappa is offline   Reply With Quote
Old 02-19-2012, 09:29 PM   #17
Rewards Points: 264
drew,
Since you hired an electrician, and since service upgrades are hard to do without permits, I think its pretty safe to assume the service panel was grounded properly. However, if you want we can tell you what to look for to confirm you have a good ground. We'd just need to know where your service panel is located (outside, basement, etc.) for starters.
As for the ceiling fan box, I don't think it's a fan rated box. Under the red wire, it looks like it's nailed vertically into either a joist or some sort of backer. The few fan rated boxes I've seen have used screws. I personally don't trust the pull out force of nails to hold a vibrating ceiling fan up.
If it were me, I'd have an electrician look at the wiring. Also, I'd replace the box with a fan rated box.
a_lost_shadow is offline   Reply With Quote
Old 02-19-2012, 11:24 PM   #18
" Euro " electrician
frenchelectrican's Avatar
I have a funny feeling I don't see how it can be set up like that due the colour and shape of the conductors are there so you may have a flying spice in there with oringal tube et knob in there and for the junciton box the centre peice is what we called bud rose ( don't laugh but it was used in old gaz luminiares days ) and that can hold a bit of weight due it have pretty hevey crossbrace to hold old hevey gaz luminaire.
It easy to get into there just unscrew the bud rose and you should able see the flying spices in there but let me give you a serious warning here ., turn off the power please due the early T&K the switched side is worked from neutral side not the hot side so be extra carefull and you may have couple old T&K conductors in there as well up above the junction box.
Merci,
Marc
Old 02-20-2012, 05:51 AM   #19
Originally Posted by frenchelectrican View Post
( don't laugh but it was used in old gaz luminiares days)
Merci,
Marc
There is that pesky gaz word again.
As much as I like knob and tube I don't think a late 1960's house has it.
Old 02-20-2012, 08:19 PM   #20
Pure Genius
Rewards Points: 150
That is not late 1960s wiring. Someone is wrong about the age of their house. Just look at that box and tell me that wire is from the late 1960's. Grounding conductors were required from 1965 and on. I would be willing to bet my paycheck that that's k and t
Dierte is offline   Reply With Quote
Crown molding and ceiling problem kirk5657 Remodeling 10 12-07-2011 02:43 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
wiring problem: 120V to 12V Halogen Ceiling Lights with transformer Uncledan Electrical 3 01-20-2010 05:32 PM
Wiring problem datoda Electrical 6 12-28-2009 07:43 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
