Ceiling Fan Wiring. Passes Through And No Ground. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 04:13 PM   #1
Ceiling fan wiring. Passes through and no ground.
Removed old ceiling fan, and replacing with new Hunter. Looks like the wires continue through the box.
The black was connected to black without going to the fan. Not sure how to attach the new wires.
In addition there is no ground on existing wiring, which I'm unable to replace. Will it work without attaching green, or better to attach the green to the white?
The new fan has a black wire, black w/ white stripe, white, and green (ground). How would I connect the wires
nimchimpski20 is offline   Reply With Quote
Old 11-09-2010, 04:41 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Use the same wires they used.
You see the black and blue wire under the wire nut.
Use that wire for the black and blue.
Put some black tape, or use a black marker to remark that wire.
The white wire connects to the other wire.
Connect the green wire to the box.
Old 11-09-2010, 07:11 PM   #3
Did you remove anything from the box, its hard to tell how its being supported.
lordlondis is offline   Reply With Quote
Old 11-09-2010, 07:39 PM   #4
Rewards Points: 150
uh-oh, someone got a switch loop backwards!
emolatur is offline   Reply With Quote
Old 11-09-2010, 07:46 PM   #5
I think your right.
Old 11-09-2010, 08:24 PM   #6
Licensed electrician
Rewards Points: 1,028
Maybe they can fix the switch loop when the box gets changed to a fan rated box.
Old 11-12-2010, 11:17 AM   #7
Ok, connected the fan the same way the previous fan was connected. Fan works great, but the lights don't.
How would I be able to tell if the problem resides in the fan or in the way the wiring is connected to the fan.
Tags
ceiling fan , electric , ground , mount , wire
