Ceiling Fan Wiring In New Construction - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 07:04 AM   #16
Rewards Points: 2,516
Originally Posted by lahatte View Post
Also, would it be possible for someone to post a diagram where the power enters at one switch location, with the fan in the middle, then the other switch location on the end?
With 4 cables entering the fan location you are going to need a large box.
-There is no neutral conductor at the location of both switches at the right of the diagram.
-No ground wires shown for ease of drawing.
ceiling fan wiring in new construction-2-20sets-20switches-20for-20fan-20light-202.jpg
hammerlane is offline   Reply With Quote
Old 03-31-2013, 07:10 AM   #17
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
one of the reasons for the change is that "some" switch were using the ground as the neutral .....
PHP Code:
Example for understanding only
ie
.. dryers/ovens .... so they are all 4 wire now in the old 2 wire system with only 2 hot you got your 240v but there was no way to run the control panels 120 unless the ground was used  .. and it was/is
so now "some" higher end switches need a pure neutral in each switch box to operate safely,
then there is the renovation aspect if a change was wanted you can easily tap the switch box cause there would be a pure Hot, Neutral and a ground there ...
next if there is a "junction" in the Fan ceiling box how would anyone know ?? Definately not the preferred method
Philly Master is offline   Reply With Quote
Old 03-31-2013, 06:42 PM   #18
Originally Posted by Oso954 View Post
Direction control is normally on the fan. If you want it on a wall control, there are only a limited number of fans with that feature. If you are going for one of those, post the make and model of it.
Could you post some models that support direction control via a wall switch?
Thanks.
Clay
lahatte is offline   Reply With Quote
Old 04-01-2013, 01:19 AM   #19
Oso954's Avatar
Rewards Points: 1,284
Monte Carlo makes a wall mount remote control (looks & mounts like a wall switch) with the reverse function. It's the CK 300. It does not work with all Monte Carlo Fans, so you need to select a model that will. Best done from a Monte Carlo catalog.
Sea Gull Lighting also sells the same control under a different model number, and a number of fans that use it.
Casablanca sells the W-85. It's a six speed control, so again, it does not work with all Casablancas.
When you start pricing these, ask questions. Light kits are often sold separately from the fans. The remote receivers are also sometimes sold separately from the transmitters.
You may be in for some sticker shock.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
lahatte (04-01-2013)
Old 04-01-2013, 07:54 PM   #20
So, just reversing the polarity of the two feed wires isn't going to reverse the direction? I suppose direction is determined then by capacitor polarity?
Old 04-01-2013, 07:58 PM   #21
Rewards Points: 516
NO ... little slide switch on the side of the fan ... you only have to change it 2 times a year ..
Old 04-01-2013, 08:04 PM   #22
No, I mean, what technically causes the motor to spin one way or another.
ceiling fan/1950's low voltage wiring mkonecko Electrical 7 10-19-2012 11:18 PM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 10:42 PM
My ceiling fan wiring problem jkrodger Electrical 9 08-13-2007 03:51 PM
