Ceiling Fan Wiring In New Construction - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 09:24 AM   #1
ceiling fan wiring in new construction
I will be running new wires to a master bedroom renovation and would like to wire the ceiling fan (a Hunter) so I can control the light and fan independently from two locations. For example: one switch for the light one switch for the fan at the entrance to the room. Second set of switches at bedside. How would I wire for that?
doubledawgdare is offline   Reply With Quote
Old 06-04-2012, 09:33 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Power to the first switch location.
One set of 3 wires for each switch, in this case 2 sets to the next awitches.
One set of 3 wire cable from 2nd set of switches to the fan box
Old 06-04-2012, 09:43 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Honestly, I would just wire one set of switches and buy a fan with a remote. But if you are really set on two sets of switches, I (or someone else) can draw something up for you.
Old 06-04-2012, 09:56 AM   #4
thanks
Old 06-04-2012, 10:00 AM   #5
I'll check to see if a remote module can be added to the fan, but I'm also trying to cut down on the remotes on the nightstand! If someone wants to unleash the inner artist and draw me a diagram that would be great. Thanks for your suggestion k_buz
Old 06-04-2012, 10:35 AM   #6
Licensed electrician
Rewards Points: 1,024
Until a diagram is shown just think of this as a three way switch setup. Power to SW1, xx-3 cable to SW2 and then xx-3 to the fan. Black would be one common, red would be the other common.
Old 06-04-2012, 10:35 AM   #7
Rewards Points: 2,512
this diagram shows two sets of 3-way switches. Grounds are not shown for ease of drawing.
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
doubledawgdare (06-04-2012), k_buz (06-04-2012)
Old 06-04-2012, 10:45 AM   #8
little modification so that both left switches are for fan and both right switches for light
Old 06-04-2012, 12:50 PM   #9
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Looks good to me.
Big N8 is offline   Reply With Quote
Old 06-04-2012, 02:06 PM   #10
heres another way with power coming into the light fixture. Would need a large box at the light fixture to accomodate two-12/2 cables and three 12/3 cables. Unless someone can condense it.
Old 03-30-2013, 03:38 PM   #11
How would this (3 way for both fan and light) work if one of the fan switches is a speed/direction controller? Also, would it be possible for someone to post a diagram where the power enters at one switch location, with the fan in the middle, then the other switch location on the end?
Thanks.
Clay
lahatte is offline   Reply With Quote
Old 03-30-2013, 05:20 PM   #12
Oso954's Avatar
Rewards Points: 430
For speed control, you can just substitute a 3-way speed control for one of the fan switches shown in Hammerlane's drawing.
Direction control is normally on the fan. If you want it on a wall control, there are only a limited number of fans with that feature. If you are going for one of those, post the make and model of it.
Oso954 is online now   Reply With Quote
Old 03-30-2013, 06:41 PM   #13
I don't have a fan yet. Doing a remodel and just getting the wiring situated.
I didn't realize there are three way speed switches. However, mostly I just need the light on three way. I think I will just run another red/black/white romex from the first to the second light switch location.
Thanks.
Old 03-30-2013, 07:10 PM   #14
Philly Master's Avatar
Rewards Points: 516
this would not be CODE COMPLIANT ...
Both the Black and the White -FEED- ( and ground ) must be run to the switch first ...
Philly Master is offline   Reply With Quote
Old 03-31-2013, 07:29 AM   #15
Are you sure about that? 2009 NEC?? Not 2011.
ceiling fan/1950's low voltage wiring mkonecko Electrical 7 10-20-2012 12:18 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 09:14 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 11:42 PM
My ceiling fan wiring problem jkrodger Electrical 9 08-13-2007 04:51 PM
