Ceiling Fan Wiring Assistance - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 01:07 PM   #1
I recently installed a Harbor Bay remote controlled ceiling fan. The light works and is controlled by the remote. The fan does not work. You hear a clicking type sound from the fan when pressing the fan conrol buttons on the remote. My home was built in 1965. There is only a black and white power cord in the ceiling box. I connected all wires according to the instructions. Help!
ponses1 is offline   Reply With Quote
Old 03-21-2013, 01:21 PM   #2
Sounds like the fan may not be wired from the remote receiver. The receiver will click when it gets the signal from the remote and the light would be wired from a separate line off the receiver. Take a look at the wires from the receiver and make sure you them all going somewhere.
If it is all hooked up then you may have a bad receiver. I have had one fail on me before.
NHtransplant is offline   Reply With Quote
Old 03-21-2013, 01:32 PM   #3
Oso954's Avatar
Rewards Points: 994
A Harbor Bay ceiling fan ?????
Did you mean Hampton Bay ? Harbor Breeze ?
Oso954 is offline   Reply With Quote
Old 03-21-2013, 02:31 PM   #4
Yes, sorry Harbor Bay is one of our restaurants.
Old 03-21-2013, 02:50 PM   #5
Possible hookup without receiver
Is there a method to install it without the receiver?
Old 03-21-2013, 04:06 PM   #6
You can wire it without the remote and receiver set up. Did it come with the remote already installed or are you adding it to it?
If you know what wire brings power to the fan and what wire goes to the light you can just wire the two together and then to the hot wire. You need to have the pull chain type switch on the fan to make it work. Does the fan have that or just the remote.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Smoke, sparks and pops from ceiling fan - need assistance on proper wiring zstopa Electrical 16 07-17-2011 08:26 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Ceiling fan wiring beezlebub03 Electrical 8 05-05-2008 06:34 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
