I went to install a ceiling fan in the dining room, the builder installed nothing which is good because we are using it as my wifes office. I removed the cover plate and check power with the switch off and the wire coming from the switch had power. So I unhooked the wire from the switch and checked again and it still has power with both ends unhooked. So I checked the voltage and it read around 11 volts AC.
The only thing I can figure out is maybe a nail hit the wire(why isn't it 120 volts I don't know) The 11 or so volts isn't enough to light a light bulb, but will it do anything to the fan, maybe over time. Has or will this problem draw current and waste electricity.
I bought this house brand new in Feb of this year, there is a warranty on the house but If I can just wire the fan in and not worry about it I wouldn't have to wait until they come out to fix it.
