-   -   Ceiling fan wiring (http://www.diychatroom.com/f18/ceiling-fan-wiring-9721/)
alument 07-07-2007 08:19 PM
Ceiling fan wiring
I went to install a ceiling fan in the dining room, the builder installed nothing which is good because we are using it as my wifes office. I removed the cover plate and check power with the switch off and the wire coming from the switch had power. So I unhooked the wire from the switch and checked again and it still has power with both ends unhooked. So I checked the voltage and it read around 11 volts AC.
The only thing I can figure out is maybe a nail hit the wire(why isn't it 120 volts I don't know) The 11 or so volts isn't enough to light a light bulb, but will it do anything to the fan, maybe over time. Has or will this problem draw current and waste electricity.
I bought this house brand new in Feb of this year, there is a warranty on the house but If I can just wire the fan in and not worry about it I wouldn't have to wait until they come out to fix it.
HouseHelper 07-07-2007 09:13 PM
The voltage you are reading (with a digital meter) is known as phantom voltage and will disappear as soon as a load is placed on the circuit. Check that same circuit with an analog meter or with a solenoid tester (Wiggy), there will be no voltage present.
alument 07-07-2007 11:21 PM
Cool thanks, glad I hadn't called the builder yet, they would have laughed.
Fan is already in and works great!
JohnJ0906 07-08-2007 10:35 AM
Please tell me that the box was rated for fan support. Regular ceiling boxes are NOT suitable to support a ceiling fan.
