Ceiling Fan Wiring 9 Wires Excluding Fan Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 01:50 PM   #1
Ceiling Fan Wiring 9 wires excluding fan wires
I have wired many ceiling fans and until today im lost. Most fans I wired had only 3 wires Black,White,Green. Which is simmple hook the colors to their match and then the blue to the black. Perfect I have even run some off extnsions cords with no problems. Today I said I would help a friend hook up 2 fans in her house and in one of the boxes their were 9 wires I assumed coming from the (1)breaker box, (2)light switch and (3)one joining another room probably on same circuit. How do I wire this fan and light assembly.Started to tell her to call a electrician. I assumed this would be about a 45 minute easy job, that was 3 hours ago.
bigswole is offline   Reply With Quote
Old 01-02-2012, 02:01 PM   #2
Julius793's Avatar
Tell us what color wires you found and which of them have constant power or switched power. Also a picture would help
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-02-2012, 02:10 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bigswole View Post
...in one of the boxes their were 9 wires
I assumed...
Don't assume.
Start by identifying the separate pieces of romex, and
what colors are in each set, and
which set is the feed (always hot).
There would commonly be seven wires and 3 pieces of romex btw...
2 for feed in + 2 for feed through + 3 for switch leg =7
hth
Old 01-02-2012, 04:18 PM   #4
Wire descriptions
There are 3 sets of romex wires with 3 wires in each, The colors are white, black and Green ground wire.
(3) Power Enters At Ceiling Box 3
(3) Circuit Continues On to the Next Room Ceiling Fixture which will become 2nd fan
(3) One Wall Switch For Light
This is the 1st incident I have encountered wher i just didn't have the basic 3 wires.
Old 01-02-2012, 04:29 PM   #5
"I beleive that the power source wires are constantly hot and come in on the same side as the wall switch, on the opposite of the box is the other 3 wires that run to an ajoining circuit". The wire colors are black& white and 1 ground wire" Excluding the ground wires there is only 6 wires."
Old 01-02-2012, 04:47 PM   #6
MarginallyQualified
OK. I didn't include the ground/green as whatever else is going on...
the grounds are always connected together. You have six wires not nine.
(3) Power Enters At Ceiling Box 3 <--"feed" 2W
(3) Circuit Continues On to the Next Room <-- "feed through" 2W
(3) One Wall Switch For Light < -- "switch leg" 2W
The feed and feed through blacks: wirenut together with
the switch leg WHITE (yes, it gets tied to the feed BLACK).
(a piece of tape on the white is a nice touch)
The feed and feed through whites:wirenut together.
(another short piece of white wire added to this is a nice touch)
The switch leg black and the short piece of white (or wire-nutted whites)
then can go to the light fixture. Done.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
bigswole (01-02-2012)
Old 01-02-2012, 05:06 PM   #7
Rewards Points: 83
davido30093 is offline   Reply With Quote
The Following User Says Thank You to davido30093 For This Useful Post:
ceiling fan/1950's low voltage wiring mkonecko Electrical 7 10-19-2012 11:18 PM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
confused re wiring on ceiling light stel Electrical 6 08-07-2011 02:22 PM
Ceiling Fan with light wiring? Snowwolf Electrical 7 06-28-2010 08:30 PM
Ceiling Fixture Wiring Issue trillen88 Electrical 4 04-13-2009 06:07 PM
