Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 05:18 PM   #1
Ceiling fan wiring
My house was built in 1959. There is no ground wire,and the outlets are polarized. I'm trying to install a Hunter Ceiling fan in the main bedroom. The goal is to replace the ceiling light fixture which is controlled by a light switch on the wall.
I've removed the fixture and installed a 2x4 brace between the joists. I noted there are two wire sheathed covered wires for the original fixture. One cloth sheathed wire has a red and black wire, and the other a white and a black wire. The two black wires are capped together. leaving the red and white wires connected to the old ceiling light fixture.
As you know the Hunter Fan has 1 black, 1 black and white, and 1 white wire.
Obviously, I attach the white fan wire to the white ceiling wire but what about the red wire from the ceiling and the black and black&white wires from the fan?
CalicoGuy is offline   Reply With Quote
Old 06-02-2010, 05:20 PM   #2
Master Electrician
for single switch operation you would attach the black and the black/white to the red and the white to the white.
i'm assuming the black/white is your fan power.
andrew79 is offline   Reply With Quote
Old 06-02-2010, 05:23 PM   #3
Master Electrician
Rewards Points: 3,916
Connect the red from the old fixture to the black and the black/white of the ceiling fan. The whites connect to each other as you have done. Leave the two blacks in the ceiling wire nutted together.
brric is offline   Reply With Quote
Old 06-02-2010, 06:40 PM   #4
Guys, Thanks! The fan and fan light are working great. Thanks again.
wiring a ceiling suspended projector amakarevic Home Theater 7 03-26-2010 08:25 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 01:01 PM
HELP! - Ceiling light wiring bryankerr Electrical 2 10-11-2009 02:08 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
