Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 12:27 PM   #1
Ceiling fan wiring
I have power into ceiling fan in a middle of the line run, and have two wall switchs, one that operates fan/light and the other switch that operates an outside light. Both switches draw power from the ceiling box. How do I wire this for operation. It used to work, but I took it down for remodling and now can't figure out how to make everything work properly. Please help! I do know that it had two jumpers in the box, but can't remeber how they were attached.
DaveLori is offline   Reply With Quote
Old 10-06-2012, 12:58 PM   #2
Rewards Points: 6,652
So, you are saying that you have a Switch Leg for the lights. Easy install.
Old 10-06-2012, 02:53 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What are the wire colors in the switch box?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-06-2012, 03:47 PM   #4
Originally Posted by DaveLori View Post
I have power into ceiling fan in a middle of the line run, and have two wall switches, one that operates fan/light and the other switch that operates an outside light. Both switches draw power from the ceiling box. How do I wire this for operation. It used to work, but I took it down for remodeling and now can't figure out how to make everything work properly. Please help! I do know that it had two jumpers in the box, but can't remember how they were attached.
I believe you are saying you have four sets of wires going into the ceiling box for the fan/light. We will call the wires that have power Romex A, the wires that go to the SWITCH for the fan/light Romex B, the wires that go to SWITCH the outside light Romex C, and he wires that go to the outside LIGHT Romex D. You must first figure out which wires are A, B, C and D.
1. Turn off power.
2. Connect all of the ground wires by twisting them together.
3. Take the black wire from Romex A and connect it to the Black wires from Romex B and Romex C. Cap those three wires together.
4. Wrap black tape around the white wires of both Romex B and Romex C. The reason for that is the white wires will be hot after going through the switch and white wires should never have "hot" on them. So make them black by using electricians tape or heat shrink.
5. Connect all white wires (except the ones with black tape on them) together and cap them. You will also want to connect the white wire from the fan to the white wires. Here you will have connected the white wires of Romex A, Romex D, and the light/fan.
6. Connect the white wire you placed black tape on from Romex B to the black and blue wires of the ceiling fan/light.
7. Connect the white wire you placed black tape on from Romex C to the black wire of Romex D.
8. Install fan.
9. Turn on power.
10. Check for working lights.
riddlers is offline   Reply With Quote
Old 10-06-2012, 04:00 PM   #5
Rewards Points: 2,516
try this...grounds not shown for ease of drawing
hammerlane is offline   Reply With Quote
Old 10-06-2012, 04:33 PM   #6
electures's Avatar
Unless one of the cables is 14/3.
Old 10-06-2012, 05:39 PM   #7
Yes,
We need more details. A couple of us have taken his question different ways.
Old 10-06-2012, 06:19 PM   #8
Originally Posted by riddlers View Post
Yes,
I agree
Old 10-07-2012, 04:23 PM   #9
electures's Avatar
This question can't be answered without more info.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-22-2011 11:04 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
