Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 08:45 PM   #1
ceiling fan wiring
Hi, newbie to the forum, and very basic skill set for DIY projects, so please be kind, and keep it simple... I took down an old ceiling fan/light today, neglecting to note which wires were connected to which wires. The old fixture had pull chains, one for fan, one for light. There was a wall switch connected, however it only controlled power to the light.
WALL SWITCH
On the wall switch there were two black wires connected to the bottom terminal screw, one red wire connected to the top terminal screw. There are what appears to be three white wires behind the wall switch, in the wall switch box, in the back of the box, but I cannot determine what or how or if they are connected to anything by looking behind the switch.
CEILING BOX
On the ceiling box, there are three black wires twisted together, three white wires twisted together and one red wire.
NEW FAN/LIGHT FIXTURE
Hunter Stratford, one black wire, one black/white wire, one white wire. Green pigtail on fixture mounting plate (ground I assume). The old fan/light fixture had a blue wire just for the light, but the new fixture connects internally with its own plug to the fan. How do I connect the new fan/light and switch?
kenlocke is offline   Reply With Quote
Old 09-15-2012, 09:04 PM   #2
Pure Genius
Rewards Points: 150
Red in ceiling box to light control wire on fan. Black to fan control. Whitea to neutral on fan
Dierte is offline   Reply With Quote
Old 09-15-2012, 09:45 PM   #3
Electrical Contractor
kbsparky's Avatar
1) Connect the white wire to the bunch of white wires.
2) Connect the black wire to the bunch of black wires.
3) Connect the black/white stripe wire to the red wire.
Do not change anything in the wall switch.
-KB
Old 09-16-2012, 10:15 AM   #4
one more question
Thank you for the suggestions, I will try after today. However, can you tell me why there are three black wires coming down though the ceiling box, but only two black wires at the switch? Also, do I untwist the wires before adding the fixture wire to each bundle, or do I just add the fixture wire to the already twisted wires?
Old 09-16-2012, 10:34 AM   #5
Licensed electrician
The ceiling box may have power in, power out and a black to the switch.
Do not change any splices at the ceiling box. Twist the fixture wires around the ceiling wires.
Old 09-16-2012, 04:11 PM   #6
success!
Thank you for your input- fan is up and running and everything is working great!
Tags
ceiling fan wiring
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 08:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-23-2011 12:04 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
