Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 04:24 PM   #1
Ceiling fan wiring
I am installing a ceiling fan to an existing switch. I used 12/2 cable and tied. Black and black white from fan to black and white to white from ceiling fan and obviously grounded the fan.
My existing switch box had two sets of wires coming in. One set w/ blk, white, ground and the other the same w/ a red wire. They were wired to the switch red @ top right, blk from same set to bottom right and the blk from the other set to bottom right pushed in. All whites and grounds were capped.
I put new fan wire white w/ other whites and blk to top right of switch. Flipped power on, switch does not work, fan and light work fine w/ chains. What the problem is?
Limited knowledge, red wire traveler wire and the switch is in the middle of the circuit? How to fix?
Steve
Wick2269 is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 08:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-23-2011 12:04 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
