Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 08:11 PM   #1
Ceiling fan wiring
I want to put a ceiling fan out on a new deck where there is no existing electricity and the attic of the house is too small to get a new run out there. Any suggestions?
Kdurden is offline   Reply With Quote
Old 07-21-2011, 08:43 PM   #2
Just call me Andrew
Rewards Points: 1,020
You need to provide some more details on what you are trying to accomplish...then you'll get lots of responses
Andrew
secutanudu is offline   Reply With Quote
Old 07-21-2011, 11:17 PM   #3
Ron Paul 2012
I agree, I recently installed a ceiling fan in place of an old boring ceiling light. All I had to do was replace the junction box with a weight rated junction box that held between the two ceiling joists.
HandymanCA is offline   Reply With Quote
Old 07-21-2011, 11:33 PM   #4
Rewards Points: 6,652
Originally Posted by Kdurden View Post
Is there such a thing as a ceiling fan wire extension kit? (not a downrod). And is it possible to wire a ceiling fan so it can be plugged in?
Yes, it is called WTH are you talking about.
Old 07-22-2011, 02:50 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,938
I'm going to guess that you're trying to hang a ceiling fan where there's no existing power, and you want to run a cord across the ceiling and down the wall to plug it in. Don't do that.
mpoulton is offline   Reply With Quote
Old 07-22-2011, 10:12 AM   #6
Rewards Points: 682
Around here (southern california) running the wire outside the wall is usually against code. Does anyone know why? Dangerous if someone accidentally cuts it?
darsunt is offline   Reply With Quote
Old 07-22-2011, 10:16 AM   #7
Experienced
Jackofall1's Avatar
Welcome Kdurden, to the best darn DIY'r site on the web.
This new deck, is there a wall mounted fixture on the outside of the house close-by? If so why not tie into that box and run EMT to the fan mount box. Yes the light switch would have to be turned on but at least you would have your power when you wanted it.
Mark
wiring a ceiling suspended projector amakarevic Home Theater 7 03-26-2010 08:25 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 01:01 PM
HELP! - Ceiling light wiring bryankerr Electrical 2 10-11-2009 02:08 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
