Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 05:31 PM   #1
Ceiling fan wiring
In my ceiling I have only two wires, white and black. Will it run my ceiling fan with lights. If so what wires go where?
Cac1203 is offline   Reply With Quote
Old 07-16-2011, 05:36 PM   #2
Licensed electrician
Rewards Points: 1,054
You will need to use the pull chains to operate your fan. Black to black, white to white. If your box is grounded the green would go to the box.
Your box is probably not rated for fan support if your wiring is older. The box should be replaced if this is the case.
wiring a ceiling suspended projector amakarevic Home Theater 7 03-26-2010 09:25 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 02:01 PM
HELP! - Ceiling light wiring bryankerr Electrical 2 10-11-2009 03:08 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
