Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 05:57 PM   #1
ceiling fan wiring
If we have a light with 2 switches and 1 is a dimmer switch can we replace the light with a ceiling fan? Do we need a special ceiling fan or will anyone work? The guy at Menards said I only need to replace the dimmer switch with a 3-way fan control switch and then we can use any ceiling fan.
brewfan is offline   Reply With Quote
Old 06-17-2011, 06:25 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Your Menards associate is probably right. You would most likely have to replace the dimmer, as it probably isn’t rated for use with a fan. There’s a good chance you’d have to replace the light box in the ceiling with a box that is fan rated also. Menards carries ‘old work’ fan box kits. They come with a bar you mount through the ceiling hole, between the joist, then the box gets mounted to the bar. Easy DIY project. Shut off the power first, and take down the light to see what kind of box you have there now.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
brewfan (06-18-2011)
wiring a ceiling suspended projector amakarevic Home Theater 7 03-26-2010 09:25 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 02:01 PM
HELP! - Ceiling light wiring bryankerr Electrical 2 10-11-2009 03:08 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
