Old 05-19-2011, 10:08 AM   #1
Ceiling Fan Wall Control
I replace the wall control for my ceiling fan and forgot the set the fan on high using pull chain before rewiring. Do I need to disconnect to wall control or will shutting the breaker off work in order to set the speed.
tigerwil is offline   Reply With Quote
Old 05-19-2011, 10:16 AM   #2
A "Handy Husband"
rjniles's Avatar
Nope, just change the fan speed with the pull chain.
When I install a remote, after setting the speed on high and testing, I cut the chain short so that no pne messes with it.
Coastal South Carolina
rjniles is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Ceiling vs wall primer simonb Painting 1 09-05-2010 12:23 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
ceiling fan remote wall control wiring akchris Electrical 6 12-15-2009 07:37 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
