Ceiling Fan W/lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 03:32 PM   #1
ceiling fan w/lights
I have a ceiling fan in my dining room & the switch that turns it on has a dimmer. I've noticed that when I turn the lights on & dim them the lights flicker. I've actually had to change several bulbs because they just shorted out not even using the dimmer.
How do I fix this shorting out problem?
cvtlavt is offline   Reply With Quote
Old 01-14-2011, 04:21 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
Flickering at low dimming settings is common, especially with older dimmers. It's considered normal behavior, though undesirable. What do you mean by "shorted out"?
mpoulton is online now   Reply With Quote
Old 01-14-2011, 04:42 PM   #3
Rewards Points: 1,418
Are these compact fluorescent lights?
CFL's will not work with dimmers unless the dimmer is meant for the CFL's or the CFL's are meant to be dimmed. Without compatibility, damage to either the lamp or the dimmer (or both) can occur even if you turn the dimmer quickly to high and later, quickly off.
Old 01-14-2011, 04:51 PM   #4
the ceiling fan w/lights short out w/ both kinds of light bulbs.
Old 01-14-2011, 05:39 PM   #5
Rewards Points: 590
If you use incandescents on a ceiling fan, you also need to get the bulbs that tolerate vibration. That may be why those are dying more quickly.
If they flicker on low dimmer settings, replace the dimmer. It's not serviceable.
operagost is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 05:16 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Repairing ceiling Arnold General DIY Discussions 8 09-12-2008 09:13 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
