Ceiling Fan /w Light Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 08:56 PM   #1
Unhappy
Ceiling Fan /w light wiring question
This is my first home improvment project on a 2 year old house. I am trying to install ceiling fans. The house has ceiling fan outlet boxes with 2 wall switches to control the Ceiling light/fan. There are 4 wires coming out of the ceiling outlet box. Black (fan-hot), Red/Orange(light-hot),White(fan-light-common-neutral) and one bare copper wire (18 or less gause) which is ground. Now if I try to measue the voltage across black & white or red/orange & white. The mm shows the current for a fraction of a second and then it drops to 0. First I thought the mm is faulty and tested it in the wall plug outlet and it shows 110volt correctly and steady. Also the wall switches are turned on.
Now my questions:
1. Why the mm shows 110v for a fraction of second and then drop to 0. I checked the Main Electric Circuit-breaker board and found none of the swithces tripped. (In fact nothing marked for ceiling fans - even though the builder collected $1000 to install about 6 ceiling fan outlet box installation).
2. The fan comes with a remote control to operate both light and motor and its diagram shows only to connect to black(hot) and white(neutral).
but I do want to make it 2 way (operatable from remote and wall switch - in event the remote is lost or its battries dies).
Can you help me with this project?
Thaks in advance
beachbone is offline   Reply With Quote
Old 02-04-2009, 09:09 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Do you get anything when you test black and red to ground? If so, sounds like an open neutral.
wirenut1110 is offline   Reply With Quote
Old 02-04-2009, 10:08 PM   #3
If your fan/light has a black,white and blue wire:
A) Throw away the remote and use just the wall switch for operation.
B) Only hook the fan to the remote and hook the light (blue) to the red controled by the wall switch.
C) Hook up the remote and use it exclusively.
The fan needs 120V power to operate the remote system. The power is controled by the wall switch. If you hook the remote up you will have to depend on it entirely.
As far as the tester, I would blame the meter or operator error.
220/221 is offline   Reply With Quote
Old 02-04-2009, 10:35 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I wish people wouldn't use digital multimeters for this kind of testing. Use a simple light tester. It's likely you aren't maintaining good contact with both wires with your probes. You can't have 120 volts one second at then nothing the next. Unless you have a very loose connection in a wirenut but I don't think you have any in that box.
220/221 has pretty well summed up your options. You can't have the best of both worlds.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-04-2009, 10:42 PM   #5
Probably set to DC or something and shuts off.
HELP! lighting question for vaulted ceiling pauls General DIY Discussions 5 07-03-2010 04:53 PM
Question about a circuit and wiring..... whowadat Electrical 5 01-14-2009 04:59 PM
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 10:00 AM
help drawing a wiring diagram kaosama05 Electrical 26 02-23-2008 08:15 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
